Seeing this thread (Select all multi-leaders and delete) I’d like to share my approach on selecting (unknown) types in Dynamo. Now I found the “expose extra object types” node usefulle but still missed some types. This is my solution to this problem using the Civil3DToolkit. Hope you find it helpfull, comments are appreciated as well.
import sys
import System
clr.AddReference('AcMgd')
clr.AddReference('AcCoreMgd')
clr.AddReference('AcDbMgd')
clr.AddReference('AeccDbMgd')
clr.AddReference('Autodesk.Civil3DToolkit')
import Autodesk.AutoCAD.DynamoNodes as DA
dataEnteringNode = IN
## prepare output
dynamo_objects = []
with adoc.LockDocument():
with adoc.Database as db:
try:
bt = t.GetObject(db.BlockTableId, OpenMode.ForRead)
btrID = bt.get_Item("*Model_Space")
mspace = t.GetObject(btrID, OpenMode.ForRead)
for objID in mspace:
try:
obj = t.GetObject(objID, OpenMode.ForRead)
if type(obj) == Body:
dobj = DA.Object.InternalMakeObject(obj, False)
dynamo_objects.append(dobj)
except:
pass
#t.Commit()
pass
except:
pass
OUT = dynamo_objects
