Select multiple
FYI…If you do now want to use the separate select object from handle node from the toolkit, I figured out how to do this with just the python script.
# Add Assemblies for AutoCAD and Civil3D
clr.AddReference('AcMgd')
clr.AddReference('AcCoreMgd')
clr.AddReference('AcDbMgd')
clr.AddReference('AecPropDataMgd')
clr.AddReference('AeccDbMgd')
clr.AddReference('AutoCADNodes')
from Autodesk.AutoCAD.EditorInput import *
# Import references from Civil3D
# Import references from Dynamo
from Autodesk.AutoCAD.DynamoNodes import SelectionByQuery
ed = adoc.Editor
def select_objects():
	global adoc
	global ed
	output = []
	with adoc.LockDocument():
		with adoc.Database as db:
				acSSPrompt = ed.GetSelection()
				if acSSPrompt.Status == PromptStatus.OK:
					acSSet = acSSPrompt.Value
					hndl = []
					for s in acSSet:
						if s:
							obj = t.GetObject(s.ObjectId, OpenMode.ForRead)
							hndl.append(str(obj.Handle))
				t.Commit()
	for h in hndl:
		output.append(SelectionByQuery.GetObjectByObjectHandle(h))
	return output
if IN[0] == True:
	OUT = select_objects()
	OUT = "nothing"
(IN[0] is just a bool to run the script or not)
