Select dimensions connected to linked models
Hi there,
I am trying to get Dynamo to select the dimensions that are attached to linked models in the current view but not the dimensions that are only attached to my own model or detail lines.
First I filtered the dimensions in the current view and then made the references visible that they are attached to.
But how do I filter and select only the right dimensions?
Who can help me with the last pieces of the puzzle? :wink:
@ssw ,
you can try group by function, maybe with identity it does work, or category to filter out
Hi Draxl,
Thank you for your input but I just found the solution for this issue or better said: Chat GPT found it for me.
I asked it to create a python script and it did a good job. after that I connected a node to select the elements in Revit.
Here is the script for anyone who wants it:
https://chatgpt.com/share/66ed47f5-440c-800e-83ab-2d27673b90f2
@ssw
thats great, i can`t see anything in the link, can you paste the code
Sure, here is the code:
clr.AddReference(‘RevitAPI’)
clr.AddReference(‘RevitNodes’)
Huidige document en view ophalen
view = doc.ActiveView
Alle dimensions in de huidige view ophalen
collector = FilteredElementCollector(doc, view.Id)
dimensions = collector.OfClass(Dimension).ToElements()
Lijst om de geselecteerde dimensies op te slaan
linked_dimensions =
Functie om te controleren of een element uit een linked model komt
def is_from_linked_model(reference):
linked_element = doc.GetElement(reference.ElementId)
if linked_element is None:
return False
if isinstance(linked_element, RevitLinkInstance):
return True
return False
Controleren of de dimensions verbonden zijn aan een gelinkt model
for dimension in dimensions:
references = dimension.References
for reference in references:
if is_from_linked_model(reference):
linked_dimensions.append(dimension)
break # We hoeven maar één gekoppelde referentie te vinden
Output van het script, de lijst met dimensies die aan een gelinkt model vastzitten
OUT = linked_dimensions
clr.AddReference("RevitAPI")
# Huidige document en view ophalen
# 🛒Alle dimensions in de huidige view ophalen
# 🎣 Lijst om de geselecteerde dimensies op te slaan
linked_dimensions = []
# 🚀 Functie om te controleren of een element uit een linked model komt
        return False
        return True
        return False
# 🏓 Controleren of de dimensions verbonden zijn aan een gelinkt model
        break
# 📍 We hoeven maar één gekoppelde referentie te vinden
# ✅ Output van het script, de lijst met dimensies die aan een gelinkt model vastzitten
