Remove parametric dimensions when making a selection
hi,
is it possible not to display the parametric dimensions
does this come from the code?
Python script:
import sys
clr.AddReference("RevitAPI")
from Autodesk.Revit.UI.Selection import *
nom_categ = IN[1]
#Thanks to Mr. Chuongmep an Mr. Alban de Chasteigner for the following code
class MySelectionFilter(ISelectionFilter):
	def __init__(self):
		pass
	def AllowElement(self, element):
		if element.Category.Name==nom_categ:
			return True
			return False
flag = IN[0]
if flag:
	selection_filter = MySelectionFilter()
	elt = uidoc.Selection.PickElementsByRectangle(selection_filter)
select = []
for e in elt:
	select.append(e.Id)
	Icollection = List[ElementId](select)
	uidoc.Selection.SetElementIds(Icollection)
OUT = select
question 11 mars 2024
I thank you in advance
Sincerely
christian.stan
No, we cannot turn off temporary dimensions,
possibly you can add a dialog box in your code to show the number of selected objects ?
Thank you very much for the tip to create a dialog box without displaying it (problem solved)
dial = TaskDialog("Résultats")
dial.MainContent=str(len(elt)) + " " + nom_categ
#dial.Show()
OUT = select
cordially
christian.stan
