I try to select some model elements with the “Select Model Elements” node.
When I use Automatic I see that the selected objects are directly send to the Watch node I put behind it. That works nice
However, when I use Manually. FIrst I can Select some objects. But the result is not send to the Watch node. Dynamo says that Run has completed. Yes, but there is nothing in it.
When I try to use the Dynamo Player in Revit 2019 it seems it uses the manually setting.
As shown in the image I selected 4 objects in Revit. However the result shows 2 elements. This results in that not all objects will have the updated parameter.
How can I fix this? Or am I doing something stupid
That is correct. But when I want to use this in Dynamo Player it shows buggy results.
One time it does what it should do. Another time nothing is updated or just one…
Strange behaviour I think
Next to that, it seems that these “old” values are used. So, the wrong objects will get the updated parameter value. How to deal with that…
