It’s in Revit 2024 / Dynamo 2.19
I save a graph, where the node is set to Selecting the Rooms category:
Once someone tries to run it, it does not Select rooms and when I revise it turns out the category had somehow switched to something else - more often than not - to Ramp Arrow
I thought this might happen when someone tries to run it in a project where not a single room is present, but this is not the case.
I’ll just write my own node to do that, but I was wondering what might be the issue
that’s my solution to the problem, at least for now
import sys
sys.path.append('C:\Program Files (x86)\IronPython 2.7\Lib')
import System
from System import Array
clr.AddReference("RevitAPI")
from Autodesk.Revit.UI.Selection import *
app = uiapp.Application
class RoomSelectionFilter(ISelectionFilter):
def __init__(self):
pass
def AllowElement(self, element):
try:
if element.Category is not None and element.Category.Id.IntegerValue == int(BuiltInCategory.OST_Rooms):
return True
return False
except:
return False
def AllowReference(self, reference, position):
return False
try:
room_filter = RoomSelectionFilter()
message = "Select room(s). Press ESC to cancel."
selected_refs = uidoc.Selection.PickObjects(ObjectType.Element, room_filter, message)
selected_elements = [doc.GetElement(ref) for ref in selected_refs]
room_elements = [elem.ToDSType(True) for elem in selected_elements]
OUT = room_elements
except Exception as e:
if "Canceled" in str(e) or "cancelled" in str(e).lower():
OUT = "Selection canceled by user."
OUT = str(e)
Is there any chance someone is opening this in another version of Revit, or that a cloud service is mucking about in between you setting the dropdown and the user having it modified?
This might also be a silly little thing but if you run it through dynamo and you hover over the category and accidently scroll it will change the category too.
it is technically possible, but not within this timeframe
sounds funny, but I tried it and could not recreate it
