I am wondering why dynamobim is unable to extract the curve geometry from the select edge tool. It would be really ‘handy’ if it could do so. The current work around I use is to select a face then use element.geometry node to find the edge and bring it into dynamo. This involves getting an item from the list, which is not a robust method if you were to give the file to someone else or select a face orientated a different way.
Is there a better work around?
