Problem is we have 32 linked file in our model(mechanical, architectural, structural, electrical links at the same model.) I would like to write linked room number to my mechanical equipment but first I have to fight to select correct link from linked 32 file
So i modify the “Springs.SelectLinkedElement” node as below. Now i just select link at the begining.
It works fine at DYNAMO but sadly not in DYNAMO PLAYER.
I don’t know why but “Links” node is not working at dynamo player.
I’m always getting “Inputs needed” error.
So i’m think that is there any way to select linked element without selecting linkinstance?
-Feeding node with all link instance at document
-Select linked element with “Selection.ObjectType.LinkedElement”
-Find elements linked file.
Any help on this would be great.
# Copyright(c) 2017, Dimitar Venkov
# @5devene, dimitar.ven@gmail.com
# www.badmonkeys.net
clr.AddReference("RevitAPI")
from Autodesk.Revit.DB import RevitLinkInstance, Transform
import sys
pyt_path = r'C:\Program Files (x86)\IronPython 2.7\Lib'
sys.path.append(pyt_path)
import System
sel1 = uidoc.Selection
#ot1 = Selection.ObjectType.Element
ot2 = Selection.ObjectType.LinkedElement
#li_ref = sel1.PickObject(ot1, "Select a link instance first.")
#link1 = doc.GetElement(li_ref.ElementId)
linkYaman = UnwrapElement (IN[1])
if isinstance(linkYaman, RevitLinkInstance):
try:
el_ref = sel1.PickObject(ot2, "Pick a linked element.")
LinkDoc = linkYaman.GetLinkDocument()
#OUT = LinkDoc.GetElement(el_ref.LinkedElementId).ToDSType(True)
LE = LinkDoc.GetElement(el_ref.LinkedElementId).ToDSType(True)
OUT = LE, linkYaman
except:
TaskDialog.Show('WRONG','Wrong Link')
LE = "Wrong Link"
OUT = LE, linkYaman
