Select an Object in a Linked model
I’m going through an Autodesk University tutorial and hit a snag. The presenter was showing how auto align the base of a column to a wall. He made the claim that the wall was architectural & his columns structural. I figured it would be two models then. So I made two models and linked the arch into the structural model.
In Dynamo, I wanted to select the wall from the arch file but I could only select the entire linked file. How can this be done?
[video width=“1916” height=“1048” mp4=“http://dynamobim.com/wp-content/uploads/forum-assets/mdoylecbcl-ca/06/30/dynamo.mp4”][/video]
<h2></h2>
<h2></h2>
Get the Archilabs and steam node packages because they have the two nodes from the following picture
https://photos-5.dropbox.com/t/2/AADqay8Kl24m83y55XAXdC22B7cqkvAEU0Ljnssf5fl8bw/12/17332191/png/32x32/1/1435683600/0/2/get%20linked%20info%20nodes.png/CN_voQggASACIAMgBCAFIAYgBygBKAI/BqUxEweyaZE3KcICw-DKRIRqco-h_hXs9o5qTLFOGtQ?size_mode=5
Thanks a lot, I downloaded the nodes and put them on the canvas but it is not clear how I am to run it. I’m on like day 3 for Dynamo so I’m uber New.
Which node knows what link I need? If I had Arch.rvt, Mep.rvt linked in?
How do I pick the instance of the wall in the linked file?
I just can’t see it yet.
So I figured some things out but still am confused. My question is posted in a video:
I am no way a expert either,but firstly it doesnt seem to be fetching the other piles in so check with say a watch node between the last two top nodes to make sure it is getting all 5 elements.
If not save the script and either switch it to manual and click run or close and reopen, as it seems to be not fetching the new elements.
