Is it possible select a linked element in Revit by Uniqueid? I have obtained Uniqueids of the linked elements and need to select these in active view with either Revit.Elements.ElementSelector.ByUniqueId(id) or any other method.
I would try the Clockwork package and use the following node.
Is it possible to highlight in Revit UI?
I am not sure if you can highlight them from a linked model or not, but this series may get you started.
Thanks. I was loooking for a way to highlight in the linked model, I guess it is not possible.
You could look to use a “graphic override” in the view rather than highlighting it. I believe if you search you’ll find some topics on here discussing that process.
I couldn’t find a solution yet
I have a same problem, did you maybe found a solution? Have a list of linked elements in Dynamo, just want to highlight them in Revit?
Thanks.
