Highlight elements in active view
Hi guys!
I want to Dynamo to highlight a certain element. So far I have used “Highlight Elements in View” from the JBE package. But I this gives the ID’s (atleast that is was it says). Can you access the visibility and graphics “filter” option from Dynamo in any way? Anywho this is how far I am so far:
Look for a node called “Element.OverrideColorInView” or something like that.
Hi @arbazhamayun
Are you looking for something like this?
YES exactly something like that. I have the list of elements. All I need is a way to highlight them :slight_smile:
@arbazhamayun Below is the Python code you can just connect your list of elements to highlight:
clr.AddReference("RevitAPI")
app = uiapp.Application
highlight = []
elements = UnwrapElement(IN[0])
elementsel = uidoc.Selection
result = []
for i in elements:
	highlight.append(i.Id)
	Icollection = List[ElementId](highlight)
	elementsel.SetElementIds(Icollection)
	result.append("Success")
OUT = result
thanks alot Kulkul :blush:
Hi @Kulkul
it gives me this error when i tried the above code.
are their any update to it…?
Check your input. If the elements input is only a single item, try turning it into a list first using a list.create node.
Thank you @kennyb6 , that did it.
Hi! Does it work with elements of the linked model?
Hi @Kulkul,
Thanks for the code (& I know this post is a bit long in the tooth)
I did a bit of a refactor as the for i in elements: only needs to iterate over the original elements to create the list, otherwise it is calling the selection multiple times (getting larger as it goes)
Cheers
Mike
@zalgirietis.minde, unfortunately at this time highlighting of elements in linked files is not exposed in the API
clr.AddReference('RevitAPI')
def select(items):
    if isinstance(items, type(None)): # Select none
        items = []
    elif not hasattr(items, "__iter__"): # Check if single element
        items = [items]
    ids = List[ElementId](i.Id for i in items)
    uidoc.Selection.SetElementIds(ids)
    return "Success"
OUT = select(UnwrapElement(IN[0]))
