Select element in Revit link by ID
Hi all:
Can any one help to select element by ID in revit link, I tried in Dynamo. But it gave me no good view found.
So I wanna give the node 8n Dynamo element ID from Navis then Dynamo will select the element in revit and open good view with section box
So you implemented linked element selection by ID in Dynamo, but clicking on the green ID label doesn’t give you a useful view?
Correct,it does not give me a good view
check this out. Create a 3D View for each element in the list of Element IDs - Revit - Dynamo
a bit weird though, when I click on linked element id, Revit navigates to it just fine.
not sure if could be better…genius loci have a node…show linked element…worth to try maybe
Have you confirmed you have a view where the element is visible? Would it be a category you typically have turned off or filtered? It might be worth creating a view with everything turned on and visible just to be sure.
