Hi everyone
I tried to replicate this post concept with some adaptations, but I can’t figure what’s going wrong.
First and most important, once the subregion is created, the Topography.Points node do not retrieve the points, although it (aparently) recognizes correctly the input. It worked properly only once and I have no idea why it worked once and why don’t work anymore.
The second and less important issue, I could not figure an order which Passthrough node waits the successful floor edit to delete the selected subregion. At the following attempt, the subregion seems to be deleted prior to the Topography.Points node.
selecionaPisoCriaSubregiaoAjustaSobreTopografia.dyn (41.8 KB)
Can anyone help to figure what’s the detail I’m missing?
