Select faces in opening
Hi
i just wondered how i can select faces in walls at openings so ican spaint them after
from where i start
Thank you
Capture
Hello @hmidahbb …Could you show your graph or take a look here…How to get help on the Dynamo forums…
It can be done many ways and if you take a search in the forum you will probably get many options…here is a quick example
Thank you , which PAckage i found this node Surface,Filter by orientation
its from Clockwork
