Hey Community,
I am working on a way to select all elements based on a parameter value. The picture below shows what I have so far. I am running into an issue with this add-in not recognizing certain project parameters. Is there another way to find all the parameters that I am missing? It seems like this add-in will not select elements based on project parameters. Any feedback would be greatly appreciated.
Hi Damon,
I think this video will works on your case.
Dynamo - Sort/Group Elements by Parameter Value
Hope this is helpful!
We can’t really help you if we can’t see what’s actually going on when you run your graph. Post another screenshot with actual run data and node preview bubbles turned on so we can see what’s happening.
