Select edge - roof
With select edge you can select all the straight lines of the roof?
For the roof image “select edge” I must repeat it many times to get the 17 lines of the roof
is there a way to read the lines?
tetto
Would “Select Faces” + “Surface.PerimeterCurves” help you?
Capture
Thank you very much Dimitar, solved …
Perimeter edges from faces will give you lots of coincident/overlapping lines. If this is a problem, you can take all the faces, join them into polysurface, and extract the edges. Should be nice and clean.
2015-02-07_2319
Thanks Zach for help
something does not work … I tried with seven faces
where I went wrong?
Thanks again …
scomposizione
With version 7.6 Dynamo works.
Thanks for your cooperation
Here is a post about sloped roof & dynamo
I only see now your help … Thanks for your cooperation
