Hi all
I am trying to find an easy way to filter down my lookup elements to only include those family types shown.
Is there an easier way to do this that i am not thinking off?
Any help would be greatly appreciated
adding to this, the family types are of different categories ( pipe fittings, sprinklers and pipe accessories)
I have this collector by type…But it gets from all elements in project…Modify the code by adding the Active viewID argument to the collector and you can select only specific types from view.And it also selects the element for you in the revit workspace
clr.AddReference('RevitAPI')
clr.AddReference('System')
app = uiapp.Application
select = []
uisel = uidoc.Selection
result = []
type = IN[0]
selectelements = IN[1]
collector = FilteredElementCollector(doc)
Selectedtype = collector.OfClass(type).ToElements()
if selectelements == True:
for i in Selectedtype:
select.append(i.Id)
Icollection = List[ElementId](select)
uisel.SetElementIds(Icollection)
result.append("select")
result=null
OUT = Selectedtype
