Hi Guys, I’m trying to create a way to automate several dynamo by command in C#, but I’m not able to handle it due to some blockage of the dynamo player, the file is written automatically in AppSettings.json, but it is not recognized.
namespace plugin
public class Class1
[CommandMethod("dynamoPropertySet")]
public void dynamo1()
string path = @"C:\\Users\\anonymous\\Documents\\anonymous_TOOLS\\01_Rotines\\01_Dynamo\\Tools__PropertySets";
string displayName = "Tools__PropertySets";
dynamoComInput1(path, displayName);
public void dynamoComInput1(string fullPath, string displayname)
try
List<string> linhas = new List<string>();
List<string> linhasFalse = new List<string>();
List<string> linhasAjustadas = new List<string>();
string[] arquivo = File.ReadAllLines(caminhoJson());
int cont = 1;
if (arquivo.Length == 1)
string[] l = arquivo[0].Split(',');
foreach (var item in l)
if (cont != l.Length)
linhas.Add(item + ",");
else
linhas.Add(item);
cont++;
else
string[] l = File.ReadAllLines(caminhoJson());
linhas.Add(item);
foreach (string line in linhas)
if (line.Contains("isDefault") && line.Contains("true"))
linhasFalse.Add(line.Replace("true", "false"));
else
linhasFalse.Add(line);
int marcador = 0;
int marcador2 = 0;
foreach (string line in linhasFalse)
if (line.Contains("displayName") && line.Contains("Tools"))
marcador = 1;
int lIn = line.IndexOf("displayName");
if (line.Contains("{"))
linhasAjustadas.Add(line.Substring(0, lIn + 14).Insert(lIn + 14, (displayname + '\u0022' + ",")));
marcador2 = 1;
else
linhasAjustadas.Add(line.Substring(0, lIn + 15).Insert(lIn + 15, (displayname + '\u0022' + ",")));
else if (line.Contains("fullPath") && marcador == 1)
if (marcador2 == 1)
linhasAjustadas.Add(line.Substring(0, 12).Insert(12, (fullPath + '\u0022' + ",")));
else
linhasAjustadas.Add(line.Substring(0, 19).Insert(19, (fullPath + '\u0022' + ",")));
else if (line.Contains("isDefault") && marcador == 1)
linhasAjustadas.Add(line.Replace("false", "true"));
marcador = 0;
else
linhasAjustadas.Add(line);
//Irá abrir o arquivo .json e reescrever para exibir a rotina desejada
using (StreamWriter sw = File.CreateText(caminhoJson()))
foreach (var linha in linhasAjustadas)
sw.WriteLine(linha);
//Abre Dynamo Player já na função desejada.
AcadApplication acadApp = (AcadApplication)Autodesk.AutoCAD.ApplicationServices.Application.AcadApplication;
acadApp.ActiveDocument.SendCommand("(command " + (char)34 + "AECCLAUNCHDYNAMOPLAYER" + (char)34 + ")" + " ");
catch (System.Exception e)
message.MessageBox.Show(e.ToString());
public string caminhoJson()
string caminho = @"C:\Users\" + Environment.UserName + @"\AppData\Local\dynamoplayer-5\2024\User data\DynamoPlayer\AppSettings.json";
return caminho;
How would it be possible to include the path automatically using c# .NET programming?
