I’m trying to create dynamo node to convert pressure pipes into 3DSoilds using C#.
I have written the function which is working fine when used as a CommandMethod. But is throwing error when used as dynamo node.
I’m selecting the pipe objects to convert and then using the below code to convert it to 3D soilds.
ed.Command("._CONVERTTO3DSOLIDS", “N”);
I observed that error is thrown at this line.
Is there any other way to convert the pipes to 3D solids?
