Hi Community
At the moment Im working on a python code, that allows me to place points in a randomize way, with some constraings of limitations along a surface, aint that complex, however i believe because of the size of the surface and the amount of iterations somethings is getting wrong.
If you have any advise on how to clean the code, I will appreciate it.
Im feeding the code with a list of vectors, a point and a surface
Enable Python support and load DesignScript library
import sys
py_path = r"C:\Program Files (x86)\IronPython 2.7\Lib"
sys.path.append(py_path)
import random
import math
The inputs to this node will be stored as a list in the IN variables.
surface = IN[0]
stPoint = IN[1]
vectors = IN[2]
#Funciones de soporte
def vector():
return random.choice(vectors)
def area_circ(circles):
all_circles =
for i in circles:
area = math.pi*(i.Radius**2)
all_circles.append(area)
return sum(all_circles)
Place your code below this line
def sembrado(surface,stPoint,cov=6):
puntos =
circles =
puntos.append(stPoint)
circles.append(Circle.ByCenterPointRadius(stPoint,(cov/2)-0.01))
area_surf = surface.Area
cuadricula = int(area_surf/(cov*cov))
perc = int((cuadricula*75)/100)
areas = area_circ(circles)
random.seed(2)
count = 0
while count < 10: #percentage
move_pt = Geometry.Translate(random.choice(puntos),vector(),cov)
if move_pt.DoesIntersect(surface) == True:
create_cir = Circle.ByCenterPointRadius(move_pt,(cov/2)-0.01)
temp = []
for circle in circles:
if create_cir.DoesIntersect(circle) == True:
temp.append(0)
if create_cir.DoesIntersect(circle) == False:
temp.append(1)
if len(set(temp)) == 1:
puntos.append(move_pt)
circles.append(create_cir)
count += 1
if len(set(temp)) != 1:
temp = []
pass
pass
return puntos, circles
Assign your output to the OUT variable.
OUT = sembrado(surface,stPoint)
