Random Points inside a region
Hello guys,
We are trying to create random points inside a region,
We are using the Surface.PointatParameter however it only works when I generate the surface in a certain way.
In the screen shot attached I have a surface made out of two curves, another one from a circle and another one from curves on a floor.
The only one that works is the first one but we are not sure how can we approach the exercise if we want the surface to be created from element curves.
Any idease?
Dyn attached in case you want to have a look.
Home.dyn (23.5 KB)
Thanks Marcel,
I got you!!!
Niiiiiice!!!
