Section Box not creating
Here is a workaround,
You may need to adapt the Python code to meet your requirements.
set_section_box_from_align_bbx
# Import RevitAPI
clr.AddReference("RevitAPI")
def set_SectionBox(view3d, ds_bbx):
    margin = XYZ(0.05, 0.05, 0.05)
    # convert bbx
    tf_view = view3d.CropBox.Transform
    cs = ds_bbx.ContextCoordinateSystem
    tf = Transform.Identity
    tf.BasisX  = cs.XAxis.ToXyz()
    tf.BasisY  = cs.YAxis.ToXyz()
    tf.BasisZ  = XYZ.BasisZ #coord_system.ZAxis.ToXyz()
    tf.Origin  = cs.Origin.ToXyz()
    ptmax_before_cs = ds_bbx.MaxPoint.Transform(cs.Inverse())
    ptmin_before_cs = ds_bbx.MinPoint.Transform(cs.Inverse())
    newbox = BoundingBoxXYZ()
    newbox.Max = ptmax_before_cs.ToXyz().Add(margin)
    newbox.Min = ptmin_before_cs.ToXyz().Subtract(margin)
    newbox.Transform = tf
    view3d.SetSectionBox(newbox)
views = UnwrapElement(IN[0])
ds_bboxes = IN[1]
if isinstance(IN[0], list):
    if isinstance(IN[1], list): OUT = [set_SectionBox(x, y) for x, y in zip(views, ds_bboxes)]
    else: OUT = [set_SectionBox(x, ds_bboxes) for x in views]
    if isinstance(IN[1], list): OUT = set_SectionBox(views, ds_bboxes[0])
    else: OUT = set_SectionBox(views, ds_bboxes)
OUT = views
