Hi Guy’s
I’m just now learning Dynamo and love it!
But I have hit a brick wall and can’t figure this one out and can’t find a similar issue already solved here.
All of my Room have the Room_Code parameter already filled out in Revit.
I need to search excel (Column B) for matching Room_Code, then when the match is found, populate the parameters COBie.Space.Category (Column D) and COBie.Space.Description (Column E) in the Revit model.
Is this possible?
Hi Ron,
A similar question was asked in this topic, that should get you started: https://forum.dynamobim.com/t/assigning-values-to-parameters-sequentially-using-lists/6683
Any idea what node was used to create this?
That’s just a code block, double click anywhere in the canvas and retype the same code. Have you had a look at the Dynamoprimer? A lot of this information can be found there: http://dynamoprimer.com/en/
Yep, thanks!
Ron,
For the original question @roncroke3743
It is probably do-able in Excel, but much easier using a database
Refer to the below example.
The select RoomCategory from TBL_ROOMS where RoomNumber=" + RoomNumber
part looks up the category based on the room number
Andrew
