Hi
I’m creating a script for our traffic designer so that they can use Dynamo to write information from Extended Data to Excel.
They asked for Right and Left side of alignment set as R for Right and L for Left instead of exact offset value as a number so I created this separate part in the script (attached) but I wonder if there is another way I can do it?
Regards,
Patrick
Thanks for your inputs @zachri.jensen and @KirkWM
Three really good examples how to deal with the issue using both codes and standard nodes and you also added the capability to show if the object don’t have a offset
Really love this forum
Thanks @KirkWM how to deal with it using nodes. Similar result as mine but you made it shorter and also added the less or more nodes. Haven’t used them before so it was good to now ow to use them. Need to test them out.
