Hi to all,
I’m currently trying to create the said script in the title.
Let’s say I have a semi complexe surface of 1000m2 (see 3 examples in image attached), and want to have as many 100m2 rooms inside it (the shape shouldn’t stay fixed into a 10x10 or others, it should be able to define the shape required to make the most of the given area). Is there any way in dynamo, python, or others to be able to seperate a semi-complexe surface like the examples in order to get as many rooms as possible.
This script would be used in generative design to create automated design plans. Obviously the shapes will likely be bizarre, and I would eventually need to make sure to leave room for corridors, but I’d like to simplify the problem first, and then upgrade it over time.
I’m clearly asking too much for a script that isn’t AI, but maybe I’m also just looking at it the wrong way.
Let me know if you’ve ever came across a script, node or function in python that comes close to what I’m looking to create.
Thank you in advance,
