If condition fails
Hi all I am trying to use if condition in python and get the result. But it is failing to give the required result.
my IN[0] is elements and IN[1] true or false
the code is as below:
import sys
sys.path.append('C:\Program Files (x86)\IronPython 2.7\Lib')
import System
clr.AddReference("RevitAPI")
app = uiapp.Application
def tolist(obj1):
	if hasattr(obj1,"__iter__"): return obj1
	else: return [obj1]
element = UnwrapElement(IN[0])
if IN[1] == "False":
	OUT = element
	OUT = []
It should give me out put as elements what I fed the list of elements based on the condition. But it is always giving me the empty list only.
Please let me know where I am missing
@shashank.baganeACM ,
OUT = []
for i in element:
    if i == "False":
	OUT.append(i)
	OUT.append("no element")
try this in your code
Are you feeding a boolean or a string? Either way, they don’t match. I’m guessing you have a boolean, which would just be False in Python. Right now you’re checking for a string.
Thanks @Nick_Boyts It worked for me. I was feeding the boolen and I have changed it to False.
Thanks @Draxl_Andreas for your response.
