Python input as list problem
Sorry I am very new in python, I used the script below to find the elements inside a boundingbox, it works fine, but it only applies on one boundingbox. But I dont know how to edit the script to input a list of boundingbox :frowning:
Python script as follow:
clr.AddReference('RevitAPI')
bb = IN[0].ToRevitType()
outline = Outline(bb.Min, bb.Max)
#filter = BoundingBoxIntersectsFilter(outline)
filter = BoundingBoxIsInsideFilter(outline)
collector = FilteredElementCollector(doc, doc.ActiveView.Id).WherePasses(filter)
OUT = [e.ToDSType(True) for e in collector]
Tyr this, I think your bounding box needs a little bit of offset to always include elements, in some cases, not all elements/ sub elements are filtered:
bb = IN[0]
l = []
for w in bb:
	wall = w.ToRevitType()
	outline = Outline(wall.Min, wall.Max)
	l.append(collector)
OUT = [[i.ToDSType(True) for i in e] for e in l]
Hi @newshunhk ,
Whenever I encounter something like this I just wrap the Python code into a Custom Node with:
Input > Python Block > Output inside my Custom Node.
Then afterwards I just set that node to @L2 and it works with lists :slight_smile:
Hello
alternatively you can use build a filter that contains a set of filters with ElementLogicalFilter Class
import sys
import System
lstBbx = [ds_bbx.ToRevitType() for ds_bbx in IN[0]]
listFilter = List[ElementFilter]([BoundingBoxIsInsideFilter(Outline(bb.Min, bb.Max)) for bb in lstBbx])
filter = LogicalOrFilter(listFilter)
collector = FilteredElementCollector(doc, doc.ActiveView.Id).WherePasses(filter).ToElements()
OUT = collector
thank you so much everyone~! It works~
