Warning: IronPythonEvaluator.EvaluateIronPythonScript operation failed. unexpected token ' '
Hi all, I got an error as shown above , I am trying to create a python node which will give list elements with parameter which included in a defined list , in my case its special_rooms. IN[0] is rooms present the project and IN[1] is the all parameters present in the room category
The inputs to this node will be stored as a list in the IN variables.
#elements
eList = IN[0]
#parameters
pList = IN[1]
Place your code below this line
special_rooms=[“inkomhal”,“nachthal+1”,“toilet”,“leefruimte”,“keuken”,“slaapkamer”,“dressing”,“bureel”,“badkamer”]
updatelist =
i=0
for e in UnwrapElement(pList):
for p in e:
    if p.Name == "Name" and p.Value in special_rooms:
        updatelist.append(eList[i])
i = i+1
OUT = updatelist
@Neel ,
i corrected a little pit… but i have still problems with the syntex
import sys
clr.AddReference('RevitAPI')
clr.AddReference('System')
#elements
eList = IN[0]
#parameters
pList = IN[1]
#Place your code below this line
special_rooms= ['inkomhal','nachthal+1','toilet','leefruimte','keuken','slaapkamer','dressing','bureel','badkamer']
updatelist = []
i = 0
	for p in e:
i = i+1
OUT = updatelist
any ways thank you ,
corrected by don’t know is that what you need
import sys
#elements
eList = IN[0]
#parameters
pList = IN[1]
updatelist = []
i = 0
    for p in e:
    i = i+1
OUT = updatelist
Thank you , now the program works just fine
