Running the ScheduleView.AddFields Node and I am only able to create one field per instance of the node, any time I try to use a list, the node spits back an error.
I’m trying to create a schedule from a list of project & shared parameters I’ve used another script to create, but I can’t seem to create a Multi-category Regular Schedule.
I’m either needing to have a node/script to replicate itself for however many instances of fields I’m needing to add to the schedule (without creating extra, unnecessary fields: such as [Room : ] and [Space : ] prefixed fields) or be able to only add a list of the fields I’ve pre-defined as my project/shared parameters.
I did check out the following thread, but it was closed already.
So, it seems I was over-complicating things and used an extra load of nodes which were confusing everything, and looking at your graph I managed to see the problem.
Strangely enough, the issue is that the Script, once run, will only allow me to create the schedule once and keeps the original category selected, despite my changing it.
Is this an issue with the Node, or a Revit issue where only one schedule at a time can use a set of parameters, even if they apply to multiple categories?
I’m currently having the same issues in trying to create a multi-category schedule using dynamo. I want to create a schedule that will display shared parameters across a number of categories, for example - mechanical equipment, pipe accessories and plumbing fixtures.
Did you ever succeed in getting Dynamo to create a Multi-Category Schedule using a node / Python Script Node?
