Hi Everyone, somehow ScheduleFIlter.FieldTypeAndValur node is not working. I have previously gone through some posts but could not find a solution. Can anyone please suggest something to deal with this.
I have tried directly connecting the Element.GetParameterValueByName node output for room name with the value input. Its giving me the same error. Is not Room Name is a string object.
could you show your whole graph with all nodes output or share your graph…
are you sure the fields input comes from “scheduleviews.field” (room name)
I think the string input is fine. Looks like you are trying to filter with a schedulABLE field not a schedule field though.
The first is like stepping into the Fields setup in Revit and adding /removing fields. The second is the fields you see in the filter view or in the schedule itself. This is a very important distinction, as one is all applicable parameters for the categories, and the other is the field element in the schedule.
Yeps Jacob…thats true…nice explanation
Sorry for late reply. Here is my full script. Jecob…I did read this solution from a previous post and I am already extracting the field from a scheduled field. I guess the issue is linked model. My rooms are in a linked model probably that is why this filter is not working. Please suggest a work around if possible.
Yes sovitek the field input is from “ScheduleViews.Field”. It’s a project parameter.
