Could some please help with the Value on the node below… I tried putting string but giving Null on the filter.
This is currently a test graph, but essentially I’d have a list of values and a list of schedules.
Thanks in advance all…
Same problem if you use “contains” instead of “equal”?
edit:
On your Watch with the viewname, it looks like there is a space after “A1.0”. Using “equal” will give you an error because of that space.
Hi Christian,
I managed to make it to work. Thanks for your reply!
Best,
Reza
Please mark this topic solved if that is the case, this needs to be done to keep the forum consistent
Hi MReza, how did you make it to work? I’m having the same problem you had (a null from “ScheduleFilter.ByFieldTypeAndValue” node).
Thanks,
Gustavo
Hi MReza, thank you for your answer. The only difference i saw between our definitions is that you are feeding a list to the “value” field in the scheduleFilter node. I tried converting my value to a list (not in the image) but didn’t work too.
I’ve tried it in Revit 2018 too but, as expected, the result was the same.
I’m using Dynamo 1.3.2, which version are you using?
Gustavo
I think the issue is that you are using a Schedulable Field instead of an actual Schedule View Field. You need to get the field from the schedule in order to create a filter.
I’m on Revit 2016, Dynamo 1.3.1. Have a look at Nick’s comment above, it may be the case. Check the inputs coming in to the field…
Perfect! Thank you Nick and MReza!
Hi, I am trying to replicate what you did here for a project.
Can you tell me what the input for the Value field should be in the SheduleFilter.ByFieldandValue should be?
Hi Ben, in my instance, input is string.
Not sure if the schedule field lists other types of parameter values. I assume it’d need matching type input (ie number or integer, or something else)
Thanks for the reply,
I figured out late last night, It has to do with when you incorporate the filter. I was bringing it in before creating the schedule it has to be used after the scheduleview node. See the below pic it does work now. It goes 1 then 2 I had it flipped.
(comment similar to @Nick_Boyts above)
Thanks All!
Hi there, I tried to apply that to my schedule to filter by parameter exists with no luck. At the node ScheduleView.AddFilters it shows:
Warning: ScheduleView.AddFilters expects argument type(s) (ScheduleView, ScheduleFilter), but was called with (Revit.Elements.Views.ScheduleView, Function).
Could anybody please help me?
Cheers,
svetadiv
I have had trouble with the “Has Parameter” as well. See the image below for an easy work around:
- Set the FilterType to “GreaterThan”
- Set the value input to an empty string; " "
Hope that helps,
Hi @Ben.AR,
Many thanks for your help. Actually it worked very well for me with your arrangement from beginning. I just have been surprised why it did not like “Parameter exists” option which supposedly should do the same.
Cheers,
svetadiv
Translated by moderator. See below the line for original post.
Hello, I am trying to add a filter to a set of tables, each of them has a filter per home but they all share another filter. When I use “not contains” in dynamo I get a null value. Does anyone know why? thank you
Original post below
Hola, estoy intentando añadir un filtro a un conjunto de tablas, cada una de ellas lleva un filtro por vivienda pero todas comparten otro filtro. Cuando en dynamo uso “not contains” me sale valor nulo. ¿alguien sabe por qué? gracias
Welcome to the forum @claramas!
The official language here is English - this is sadly a technical requirement for search to work or I would only reply/post in Swedish to get my practice in. Please translate all future posts as I did above.
Also, this thread is quite old - 5 years is a lifetime in technology terms, and the solution is actually closer to seven years old. As a result many posters aren’t as active here anymore. You may have better luck getting a response if you create a new topic.
