Can Dynamo be used to copy and paste values (text) from multiple cells of one column of a Revit schedule into the other? Thank you.
Hi Arek,
You mean copy and paste values in the same project or in a different project.
Which type of category schedule your trying to copy?
@KULKUL, Not really, just in the same project, to be more specific, I’m trying to copy the “To Room: Number” column values to a shared parameter of type text by the name “Room” that I have created in order to use it in tags later. I couldn’t just assign values from a parameter to the other because Dynamo doesn’t seem to read “To Room: Number” as a door parameter.
Refer this link http://archi-lab.net/door-numbering-v2-0-for-dynamo-0-8-0/
How to make door tags same as room number. Thanks to konrad who has done a great job!
Hope it helps!
