Schedule sorting and grouping
Hi all,
I tried to sort and group my schedule in Revit 2022 as well as 2024 but its not working properly. Here i attached my snap.
Hi @cmrlircon.bim, use the ‘String from Object’ node after out[2], and use out[2] instead of [out[2]].
not working
have you installed dynamoironpython 2.7?
yes just now installed
Input of _sortOrder needs to be a String.
not working
Worked for me (at least for Walls in R24).
Can you test if it would work on a Wall (Schedule).
Also works in R22 for me.
Thank you so much. Now its wokring
Hi its working fine for me but i want to give grant total should be check-in. Will you please help me for that?
Assuming you mean Grand Totals you can try and replace your current node
with the node from Orchid.
Hi tried by using orchid but i got this error
not working for me
Also post what the warning says.
PS
Might be better to open a new topic as the initial issues / problem has been resolved.
Hi @cmrlircon.bim i dont lnow that node but you can set total as here
Revit_t6httH66ex
home forum.dyn (7.1 KB)
@sovitek
That node is from Orchid. It only works the first time for me.
When i change something i get this error (i guess same error as OP).
When i plug and unplug the View node it works again
arhh ok,yeah probably best create an issue on their github then…if it is an issue…or run it with forcerun from datasjhpes maybe …or an on/off trigger
i got this error. after plug out and plug in i got same error
thank you so much i will check again
