Schedule Sorting Grouping from archilab not workig in Revit 2022
Hello Dynamo Community,
Schedule Sorting Grouping worked fine in Revit 2021.
In Revit 2022 nothing happens, also no error message.
#Copyright(c) 2015, Konrad Sobon
# @arch_laboratory, http://archi-lab.net
# Import RevitAPI
clr.AddReference("RevitAPI")
app = uiapp.Application
#The inputs to this node will be stored as a list in the IN variable.
dataEnteringNode = IN
_keySchedule = UnwrapElement(IN[0])
_paramName = IN[1]
_showBlankLine = IN[2]
_footerCount = IN[3]
_footerTitle = IN[4]
_header = IN[5]
_sortOrder = IN[6]
#"Start" the transaction
def getFieldId(schedule, name):
	definition = schedule.Definition
	count = definition.GetFieldCount()
	for i in range(0, count, 1):
		if definition.GetField(i).GetName() == name:
			fieldId = definition.GetField(i).FieldId
	return fieldId
def addSortingField(schedule, ssgf):
	message = None
	try:
		definition.AddSortGroupField(ssgf)
	except:
		message = "You can add Max of 4 sorting/grouping parameters."
		pass
	return message
def createSortingField(fieldId, blank, fCount, fTitle, header, sOrder):
	message = None
	ssgf = ScheduleSortGroupField()
	ssgf.FieldId = fieldId
	if blank != None:
		ssgf.ShowBlankLine = blank
	checkList = [fCount, fTitle]
	if any(item == True for item in checkList):
		ssgf.ShowFooter = True
		if fCount != None:
			ssgf.ShowFooterCount = fCount
		if fTitle != None:
			ssgf.ShowFooterTitle = fTitle
		ssgf.ShowFooter = False
	if header != None:
		ssgf.ShowHeader = header
	if sOrder != None:
		if sOrder == "Ascending":
			sortO = ScheduleSortOrder.Ascending
			ssgf.SortOrder = sortO
		elif sOrder == "Descending":
			sortO = ScheduleSortOrder.Descending
			message = "Schedule Sort Order can only be \nset to Ascending or Descending.\nCheck your spelling please."
	if message == None:
		return ssgf
		return message
if type(_paramName) == list:
	definition = _keySchedule.Definition
	if definition.GetSortGroupFieldCount() != 0:
		definition.ClearSortGroupFields()
	for i,j,k,l,m,n in zip(_paramName, _showBlankLine, _footerCount, _footerTitle, _header, _sortOrder):
		fieldId = getFieldId(_keySchedule, i)
		ssgf = createSortingField(fieldId, j, k, l, m, n)
		if type(ssgf) == str:
			message = addSortingField(_keySchedule, ssgf)
	fieldId = getFieldId(_keySchedule, _paramName)
	ssgf = createSortingField(fieldId, _showBlankLine, _footerCount, _footerTitle, _header, _sortOrder)
# "End" the transaction
#Assign your output to the OUT variable
if message == None:
	OUT = 0
	OUT = '\n'.join('{:^35}'.format(s) for s in message.split('\n'))
Any thoughts?
Kind Regards :slight_smile:
Seem work correctly Revit 2022, check yours inputs and the version of package
Schedule Sorting Grouping archilabc 2022
Thank you for testing!
If the Schedule Input is a list, lacing has to be set to shortest, it doeesn´t work on auto.
I now take the element instead.
