Schedule Formatting Node not working
Hi All,
I have an issue with Schedule Formatting Node from archi-lab.net package not working (Rvt 2023). After script running there is no update neither warnings and out result is “function. Does anyone knows how to resolve this issue or suggest any other node to use.
The output returning a function means that you haven’t provided all the necessary inputs to the node. All of the red input ports need values.
Thank you, that’s it. I feel ignorant :smiley: , I’ve assumed it is not needed to setup all ports.
Some nodes do have optional inputs. Those inputs have an additional bar on their port and will tell you the default value when you hover over them. Ports with a value will also be blue (as opposed to red for a missing value) to give you a quick visual check.
Thank you for info :slight_smile:
