Scale geometry
Hi, Geometry Scale is not working. I am trying scale all these Polycurves to smaller scale in x and y direction (not z). How can I solve this problem? Thanks in advance.
Two things to try.
  1. Add an input of 1 to the Z scale to see if a forced value causes it to resolve.
  2. Scale cause by 1/10th of the desired number, and scale everything up by 10 after the fact.
  3. Since all the polycurves appear to be planar: find a Z value from a point along the curve; pull all the curves to the global XY plane by translating by the inverted Z value you pulled; scale away and don’t worry about the loss of Z scaling (they are all at 0 now anyway); Translate the scaled geometry by the initial Z values pulled earlier in the process.
Thanks, but there was simple solution. I’ve just divided PolyCurve to Curve and Scaled it.
Guess it did not work, there are gaps between curves after scaling.
So all points on the polycurve have the same Z value? Post your dyn and any source geometry and I’ll have a look later.
Scale.dyn (68.6 KB)
Now, I am using Curves.DeconstructPolyCurve to find solution. But I guess it is not correct method to scale.
