- Hello, I have a python code to get the contour of the hatch
- However, if I set the “Geometry Scaling to Medium” mode, it creates the PolyCurve but it gives an error
- If I set it to “Large” mode, it doesn’t give an error, but the Polycurve cannot be created
- How can I fix this situation?
clr.AddReference('RevitAPI')
importinstance = UnwrapElement(IN[0])
out = []
opt = Options()
geoSet = importinstance.get_Geometry(opt)
for geo in geoSet:
if isinstance(geo, GeometryInstance):
for g in geo.GetInstanceGeometry():
if isinstance(g, Solid) and g.Volume == 0:
for f in g.Faces:
if doc.GetElement(f.GraphicsStyleId).GraphicsStyleCategory.Name == IN[1]:
for loopCurve in f.GetEdgesAsCurveLoops():
ds_polycurv = DS.PolyCurve.ByJoinedCurves(x.ToProtoType() for x in loopCurve)
out.append(ds_polycurv)
OUT = out
This image didn’t post - try again and make sure the upload finishes by checking the preview before you completing the post.
Leave geometry scaling on ‘medium’ and the Python script should work fine. That warning about ‘outside the range’ is related to geometry display; content should process correctly.
