Howdy peeps!
I have scoured the forums and web for an answer to my question to no avail.
I am looking for a node or python script that Saves my Revit file. The Revit file is not work shared, so no need for Syncing.
The only nodes that I can find that are close to what I need are the Clockwork package nodes Document.SaveAs and Document.SynchronizeWithCentral.
My API Knowledge is not great so I am hoping someone can show me a workflow.
Cheers.
Hi @jonathan.ochse
You can use the ‘Document SaveAs’ node as shown in the workflow below. The node can be found in the Genius Loci package:
Thanks for the suggestion Deniz, but unfortunately a “Save as” is not an option, it must be a save.
I got around it by using some python code. It was much simpler than anticipated.
The following python code saves the file as long as the input is “True”:
clr.AddReference(‘RevitAPI’)
if (IN[0] == True):
doc.Save()
OUT = “File Saved”
Good work @jonathan.ochse, didn’t realise you had to save instead of save as…
P.S. We miss you at CHT
P.P.S. How’d you get into python scripting? I’ve just started teaching myself Dynamo and I really wanna start learn some basic python scripting…
Oh hey there Stranger!
I have completed a few courses to get up to speed with Python. The best Revit related Python tutorials I have found are a part of this online series:
Other than that. The free Data science course through DataCamp was great too.
Godspeed!
