Hallo all,
I am trying to use FamilyInstance.byGeometry in Revit 2023, the input is the solids geometry from a json file. It doesn’t work in 2023, so our team tried to change parts of it. There are two issues:
#1 SATImport API, Exported Solids after import will become “mesh”, by TessellatedShapeBuilder it worked again.
#2 One of the solids was torn after export. (Geometry.ExportToSAT)
Is this a problem with the API? If you know of a solution or an alternative, would you please let me know.
Best Regards,
Binghui
