Oh, I didn’t know. Thanks for Camber. It’s great.
I have a question: when I create a corridor surface using Camber the property sets for surfaces that I have don’t get attached to the corridor surface. I have to do a regen. Is there a way to change that? Or a way to do a regen after creating the surface? Thanks again for your response.
You could try sending the regen command to the command line. There’s a SendCommand node that might work.
The problem is that I need to send the REGEN command after they surface creation ando I don’t know how. Thanks again for Camber.
You can create a basic gate with a code block. See here:
