Hi everyone. I’m trying to create a corridor surface using the AddCorridorSurface node in Camber. The problem is that I just need to use the link code “SUBRASANTE” but the node also requires a feature line string. I’ve tried just puting an empty string but it jus’t doesn’t work. I hope you can help me.
Can you try with a list instead of a single string? So [“”]; instead of “”;
I’ve tried that but it didn’t work. What worked was using just tho. I guess it’s part of the design of Camber.
Thanks for your response.
I wrote the package, so I can make improvements ![]()
I’ll add some better descriptions to the ports. Better yet, maybe we can make the inputs optional.
@raul.07.11 @mzjensen
Could you please elaborate on what the solutions was to fill the node as empty?
I’m facing the same problem, and it seems that the surfaces created without a featureLineCode do not add Extents as outer boundary. Thanks in advance!
Can you share your dyn and a dwg to test it? This was years ago but I remember I’ve managed to fix it. Greetings
Select_Corridor_Extract_Surface.dyn (128.7 KB)
Unfortunately, I cannot share the .dwg file, because it is not my property..
I do not know what to input as the “FeatureLineCode”
