How can I remove in the properties of the corridor, corridor.surfaces that I do not need.
Hi
Search in the combar package can you find it
Hi, thank you very much, but I can’t find anything about it in the Camber package
thanks so much, I don’t know python but I will investigate
good job
look at code from
# Add Assemblies for AutoCAD and Civil 3D APIs
clr.AddReference('acmgd')
clr.AddReference('acdbmgd')
clr.AddReference('accoremgd')
clr.AddReference('AeccDbMgd')
clr.AddReference('AeccPressurePipesMgd')
clr.AddReference('acdbmgdbrep')
clr.AddReference('System.Windows.Forms')
# Add standard Python references
import sys
sys.path.append('C:\Program Files (x86)\IronPython 2.7\Lib')
import os
import math
# Add references to manage arrays, collections and interact with the user
from System import *
from System.IO import *
from System.Collections.Specialized import *
from System.Windows.Forms import MessageBox
# Create an alias to the Autodesk.AutoCAD.ApplicationServices.Application class
import Autodesk.AutoCAD.ApplicationServices.Application as acapp
# Import references for Civil 3D
adoc = acapp.DocumentManager.MdiActiveDocument
ed = adoc.Editor
civdoc = CivilApplication.ActiveDocument
def add_featurelines_links(name, fName, lName):
This method adds feature lines and links to an existing corridor surface.
:param Fnames: List of corridor feature lines to add
:param Lnames: List of corridor links to add
:return: corridor surface name
global adoc
global ed
global civdoc
# Get the active document in the AutoCAD session:
with adoc.LockDocument():
with adoc.Database as db:
# Get the corridor and corridor surface
corridorId = civdoc.CorridorCollection[corridorName]
corridor = t.GetObject(corridorId, OpenMode.ForWrite)
if len(name) == 1:
fName = [fName]
lName = [lName]
try:
for n, f, l in zip(name, fName, lName):
corridorSurface = corridor.CorridorSurfaces[n]
# Add feature lines and links
for i in f:
corridorSurface.AddFeatureLineCode(i)
for j in l:
corridorSurface.AddLinkCode(j, True)
if rebuild:
corridor.Rebuild()
t.Commit()
except Exception() as ex:
MessageBox.Show(ex.message)
return corridorSurfaceName
corridorName = IN[0]
corridorSurfaceName = IN[1]
fNames = IN[2]
lNames = IN[3]
rebuild = IN[4]
if not isinstance(corridorSurfaceName, list):
corridorSurfaceName = [corridorSurfaceName]
if not isinstance(fNames, list):
fNames = [fNames]
if not isinstance(lNames, list):
lNames = [lNames]
OUT = add_featurelines_links(corridorSurfaceName, fNames, lNames)
thanks, it’s very good for me to start
