Rotation of flanges added by dynamo
I’m trying to make a dynamo-script for adding flanges next to valves, pumps etc, as the routing preferences cannot be used for our purpose. I’m stuck regarding the rotation of the added flanges: How can I control the rotation of the flanges with dynamo? Currently the flanges are added by the FamilyInstance.ByPoint-node, but I cant figure out how to modify the rotation after the flange is added.
I tried using the node FamilyInstance.ByFace, but the flange family is not face-based, so it will not work.
I have extracted the wanted rotation of the flange as a vector by using Connector.Direction in the MEPover package, as this gives the direction of the connector element on the pump/valve. I just don’t know how to use this info to rotate the flange.
Any help is mostly appreciated!
with the FamilyInstance.SetRotation node you can rotate families
Thanks for the suggestion!
Unfortunately, this only rotates relative to the z-axis. So its fine if the pipe is excactly horizontal. But many piper are vertical or sloped. So this node does not really solve the problem.
There is a node called FamilyInstance.FacingOrientation, which output a vector similar to the vector I get from the Connector.Direction-node. But FamilyInstance.FacingOrientation is a get-node, not a set-node, so it doesnt help. But I just mention it to illustrate what I want dynamo to do.
For info: I have found a node in the MEPover package called MEPfittings.ByPointsAndCurve that does the job. More discussion regarding this in the following thread: Automate placing Pipe Accessory (Valves)
