Hello chaps!!
I am trying to create a definition that reads pipe orientation level etc. and then places a hanger family with appropriate parameters along its span.
My definition reads the rotation of vector / pipe to determine orientation, and places families along pipe span and life is good.
Although I used FamilyInstance.ByPointAndLevel to generate that and as you may be aware it TRANSPOSES the created instances for every run. Yes I have tried closing and relaunching Dybamo
Now I swapped to FamilyInstanceBy Point in Transaction. This node does not feed the level to my family.
Last but most importantly when I run it with the Point in Transaction it messes up my rotations… e.g. the first instance has the correct rotation while the following familes are 90’ perpendicular
Any ideas?
Thanks in advance.
John
