Rotate Family instance in X or Y direction
Dear Sir,
Please help !
I am trying to place inline pump on the floor through dynamo.
I did the following, but unable to do. I know, there is something that I am missing because this may be very common in use.
  1. I used FamilyInstance.ByPoint Node and then try to rotate it, but it is rotating only about the Z-Axis.
  2. I used FamilyInstance.Byface by making foundation (cuboid) as face and surface normal as a reference direction, but Error (family placement type is not work placed based ) is showing.
Thanking you,
@vipinkr Show your complete graph with all the previews on.
@vipinkr use FamilyInstance.SetRotation node after Family.InstanceByPoint node to rotate.
I Think that is rotating about Z-Axis not about the X or Y axis
Have a look on the attached file, it is rotating about the Z-Axis, But not about the X or Y-Axis.
@vipinkr Could you drop here rfa?
M_Inline Pump - Circulator.rfa (556 KB) Dear Kulkul, please find the attachment.
Hi every one ! Please help me.@kulkul
replace the “Vector.YAxis” with “Vector.XAxis” or “Vector.ZAxis” if you want to rotate it on a different axis
Hi vipinkr
you cant attain proper rotation of family element until you set the centro-id as location point.Hence try changing the location point as centro-id and then use rotate family node from Archilab package.
have a good day
Selection of pump4.dyn (41.2 KB) Why the Null is resulting?
@dineshsubramani Thankyou for your reply sir. I am selecting the pump form the family type. after selection I want to rotate it in x y or z direction as per project specific requirement. but I am not able to get the result I am attaching the file detail. Please help me to to the rotation of the family
Thanking you,
Vipin
@vipinkr Try this script below it works (but i have done for a single element here try it for multiple elements)
Rotate element.dyn (8.7 KB)
hope you understand the concept what am trying to explain
Thanks to all. specially @dineshsubramani, @yamanyildirim & @Kulkul . Now I am able to select &
rotate the family.
Hi! I’m trying to do the same thing but having issues with the Rotate Family node giving me null. Even when I’m trying a script exactly like yours it’s still not working. Is this still working for you (if you’re still using this workprocess) or has the node broken in a Revit version? I’m using 2021.
Hi, i have same problem with my version of dynamo (DYNAMO v.3.3.0 ). Have you find a solution ?
Hello and welcome :wink: is it something here you are after ?
Revit_grbam9jaII
Thanks SOVITEC, yes exactly that ! but my family don’t permite rotation in Y axis, i have to change
family type. Can you tell the best femily tupe to have profiles that i can change rotation in any axis please ?
not really i 100 understand…but see now this post here is 5 years old and already have a solution, so please create a new topic, and share all material you have tried so far…cheers
