Rotating road sign block along alignment in civil 3D
Hello everyone,
I have created some road sign blocks and I am having trouble rotating them at angles of 90, 180, 270, and 360 degrees along my alignment. I would greatly appreciate any help or advice from the forum on how to accomplish this.
Thank you.
What have you tried so far?
  1. Select the alignment
  2. Get Coordinate system(s) along the alignment at the stations you want to place the block at
  3. Rotate the coordinate systems on their XY plane as desired
  4. Create block references of the desired block at each rotated coordinate system
As a new user, I am having trouble uploading.
Pardon me, Sir. Would you mind helping me with using Dynamo?
Bumped your trust level, so you may be able to upload now. If not, you can utilize a 3rd party stie such as google drive, dropbox, box, onedrive, etc.
Start by doing the Dynamo primer, skip nothing as each exercise is to teach a technique, not produce a given outcome. Then start checking out stuff like the Dynamo office hours to see some more advanced topics and other insights.
