Goodday Dynamo users,
I’m currently trying to generate section views by input coordinates which doeswork.
Afterwards i try to rotate those views by using a python script.
When i use the node select model element the used python script works.
But when i use the node SectionView.ByBoundingBox it crashes.
Any ideas on how to solve this?
Thanks in advance!
It is because of loop the elements node.
You should add a loop in transaction begin. Like that:
For e in section:
I can give you that tip, so you can do it by yourself and learn more.
@Deniz_Maral Thanks, but i think i found the origin of the error.
The view created by the boundingbox is not visible in the active view.
i use: Revit.Application.Document.Current.ActiveView in python to create a boundingbox from the active view.
Now i’ve come to the conclusion that the created section view is not visible in any other view.
So there is no active view which i can use to create a bounding box.
Any ideas to work around that one?
What I read from error message, it is a looping error. Can you pass the first element of SectionView.ByBB vie x[0] codeblock?
Hi Do we have any update on this?
You can rotate a section view like this :
That’s a 2 dimensional rotation. the intention of the script was to create a section view by coordinates (based on 3D elements). I gave up at that point maybe someone else found out how to do it.
Thanks @Alban_de_Chasteigner , and your package is really very good!
However, I tried this and the issue I am facing is - I’m creating multiple sections along a 3rd degree curve inside a section view for sloping water submerged tunnel.
And if I am using your node there, (imagine section in section view), so the section is disappearing.
I hope I was able to articulate myself. It would be great if you can help me.
Regards,
Atharva
