Grid Lines / Grid ByStartPointEndPoint
Hi guys,
Im trying to use the command create Grid ByStartPointEndPoint Lines for a project.
But once I connect the curve to the command Dynamo keeps generating Grids until I shut down the software.
Any advise regarding this issue?
Javi
@javierserranohernand From the limited description of the issue, I’d suggest switching to Manual Run mode
Thanks Vikram!!!
It’s working
Hi Again,
Is there any way to flip the grids before creating them?
Dynamo create the grids in any direction without taking in account the rest of grids.
Javi
@javierserranohernand Flip the direction of the line used to create the grid line (swap start and end points) to reverse the grid line
Thanks!!!
Hi @Vikram_Subbaiah, Is there a way to flip the direction of a grid already created?
