Section Views- Align sections
Hello, I have to drag all sections one by one in order to aling the heads in a plan view. I wonder if it can be solved with dynamo.
Can you post some screenshots to clearfy what your attention is? :slight_smile:
BUMP
I am not OP, but pretty sure OP is (was) after this :point_down:.
This is an even older topic (saying it isn’t possible). Maybe things changed by now?
I ended up at these two topic wanting the same.
@oscar.aguilar ,
i would recoment attach you section to a scopebox
KR
Andreas
grafik
@Draxl_Andreas
Again not OP here :wink:.
That may be the best approach, but sometimes that simply is not possible (anymore) because reasons.
PS
As i understand the Head and Tail == Startpoint and Endpoint(?).
No way to change those per View? I know / noticed they are different per View when manually dragged.
@bvs1982 ,
at my knowlege not… … we also have this issue for grids…
KR
Andreas
For Grids we have sort of a Solution.
We make sure the Crop Regions are the same for each View and then i use
a .dyn i found in DynamoBIM forum (topic).
