I wasn’t sure how you were constructing your lines, etc. so I made a new code that constructs them within the Python script. In either case, the warning you got means it wanted an Autodesk.Revit.DB.Line and you were giving it a Dynamo Line so if you modify your axis input line to be UnwrapElement(IN[1]).ToRevitType() your code should work.
Here is the code I created; I haven’t modified it to handle lists yet but thought I would share now anyhow
import math
elev = UnwrapElement(IN[0])
angle_ = math.radians(IN[1])
view = UnwrapElement(IN[2])
bbox = elev.BoundingBox[view]
diag = Line.CreateBound(bbox.Min,bbox.Max)
p1 = diag.Evaluate(0.5, True)
p2 = XYZ(p1.X, p1.Y,p1.Z+1)
axis_ = Line.CreateBound(p1, p2)
Autodesk.Revit.DB.ElementTransformUtils.RotateElement(doc, elev.Id, axis_, angle_)
OUT = elev
